What are these for??
Old Mar 13, 2010 | 07:09 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
Please dont pay attention to the messy wiring in 2 of the pics, i havnt got around to doing something about that :/
The plug with the red wire is on the driver side of the car, there is an identical plug on the passenger side that has a green wire and is not plugged into anything either.
So what could these be? Are they important?
If you need more info, i can go take a look and try to answer questions
-Thanks
Attached Thumbnails What are these for??-sdc10316.jpg   What are these for??-sdc10314.jpg   What are these for??-sdc10318.jpg
Old Mar 13, 2010 | 07:13 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Re: What are these for??
another pic of the black thing
Old Mar 13, 2010 | 08:16 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
The small wire looks like the wire for your fan switch. Not sure about the bigger plug but I'll look on my car tomorrow and see what I can find out.
Old Mar 13, 2010 | 08:59 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
The black plug looks like your fan relay which should be screwed to the core support between the battery and the radiator. Ditto on the other wire.
