HVAC Issue
Old Mar 13, 2010 | 11:57 AM
Ekso's Avatar
Car: '91 Base model & '91 Trans Am
Engine: 3.4L & Gen1 SBC 350
Axle/Gears: 3.73 and 3.42
HVAC Issue
My latest purchase of a T/A definatly constitutes as a project car, and one of the issues I have no clue about it is the HVAC.
It only works on Defrost mode, (but both cold and heat can come in depending on temp slider thing), and when anything but the coldest setting is on,(so any form of heat) it hisses when throttle is applied, and only when throttle is applied...
Can anyone tell me if this is a wiring issue in the HVAC controls or should I be posting in a different category?
Old Mar 13, 2010 | 01:36 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: HVAC Issue
Sounds like there is a vaccuum line off somewhere causing the controls no to work properly.. I would check that first.
Old Mar 13, 2010 | 09:05 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: HVAC Issue
To check your vacuum, there is a vacuum ball that takes engine vacuum and then goes to a hard plastic line along the firewall, which feeds your A/C controls. This diverts the doors to move air to the different vents. Check the connection at the back of the control and make sure all the vacuum lines are secure. Same thing for the engine vacuum line.
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
