wiring harness
Old Mar 14, 2010 | 02:50 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
wiring harness
I tried the engine swap guys,and there where no coments made.I'm trying to find out if the engine wiring harness on an 1986 2.8 v6 is the same as a 1990 3.1 v6.I can find a 3.1 easyer than a 2.8 efi
Old Mar 14, 2010 | 03:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: wiring harness
Not even close. The C100 bulkhead connector needs to be rewired, the windshield wiper harness needs to be installed in the engine harness side of said C100, the gray 6-wire connector down by the ECM needs to be rewired and have some wires switched with the 15-wire connector next to it, the oil pressure sender, TPS, IAC need to be rewired, and you will need to find a way to get a VATS signal to the ECM so you have fuel delivery.
Shoot me your email addy, and I can send you the write-up I have on it...
:edit: What are you looking to do? You already have the better P4 system.
Old Mar 15, 2010 | 08:51 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: wiring harness
I found a 3.1 close to home.Just having a hard time finding a 2.8 fuel injected to go in my sons 86 bird.There is one I found 6 hours away.
Old Mar 15, 2010 | 10:29 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: wiring harness
Well, if that's the case, don't even think about touching the wiring harness. Remove the smog pump (keep the pipe in the exhaust manifold, however), upper plenum with throttle body, and the fuel rail from the 3.1. Keep the fuel injectors or don't, it's up to you, they're pretty much the same (actually, the fuel injectors used on the 88+ 2.8 were 3.1 fuel injectors). You will need to pop the plug out of the hole for the seventh cold start injector out of the back of the intake manifold (the lowest one), and put the CSI from the 2.8 in the hole. Put the nylon idle air pipe on the nipple at the back of the manifold, the hose on the PCV valve, and run the pipe to the front of the engine. Install the 2.8 fuel rail, upper plenum, and the throttle body, complete. Swap over the 2.8 alternator, oil filter adaptor (or you have to buy a connector for the single oil pressure unit), and air intake.
Install the "new" engine and crank it up. However, if the transmissions in the 2 cars are different, keep in mind that the 86 2.8 is externally balanced and the 3.1 is internally balanced. So, if you need a flywheel, you need one without a balance weight on it. Same for the flexplate... Get the plate or wheel matching the engine, not the car.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
