another wire harness Question
Old Mar 15, 2010 | 04:20 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
I am swapping my cc carbed 305 for 350 non cc I unplugged my ecm harness(pass side) on my 85 ta and removed that as one unit.What do I do about the Plug that That went to my T5 is this just for backup lights and how do I fix this.How do the other 2 harnesses unplug near the booster. I want to neating things up a little on the main harness..I did some searching but couldnt find any answers. Thanks
Old Mar 15, 2010 | 06:56 PM
dherr's Avatar
Car: 85 T/A
Engine: 383 TT
Transmission: th350
Axle/Gears: 3.55
Re: another wire harness Question
the harness near the booster should be held in by a 7mm bolt in the center of the harness on my 85 its 2 plugs (you can split them once you unbolt it) one harness is for the front lights the other for the starting/charging/wipers and i think a/c
Old Mar 15, 2010 | 07:10 PM
howy03's Avatar
yeah thanks my bolt was covered in crud so I did not notice it.Do all the harness plugs have that nasty grease on the pins and connectors?or should i clean it..Anyone on the T5 tranny plug? I just want to make sure I dont need any of the ecm harness or computer.Before I chuck it..
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
