Hooking up gauges w/ aftermarket ecu
Old Mar 27, 2010 | 06:49 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I just purchased the new Holley Dominator Ecu and I know it is able to control the speedo and the transmission, question is where do I hook up the wire that reads the vss signal from the speedo? By the way this is for a 92 trans am. Thanks
Old Mar 29, 2010 | 04:54 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Hooking up gauges w/ aftermarket ecu
Speedo requires a 4000ppm signal that passes through the C207 pin D. Should be a gray wire. TBI cars pass through pin K and are brown
Old Mar 29, 2010 | 11:40 AM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Ok so all I need to do is connect the gray wire with the wire that comes off of the ecu? Sounds alot simpler than I thought. Thanks.
gixxer92
Apr 12, 2022 12:09 AM
69GTOby
Apr 18, 2016 02:34 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
codeysabatini
Sep 20, 2015 11:36 AM
