Headlight Mystery
Old Mar 27, 2010 | 10:54 PM
zz???'s Avatar
Headlight Mystery
Here's a new one for you guys and gals. My 91 Formula's passenger side headlight will pop up at night while the car is sleeping in the garage. I can turn the motor **** down manually and it stays for a couple of hours, then slowly starts to go up. Mind you the light's do not come on, and I can cycle the headlamp switch and all operates normal. The lights turn on and the lights pop up when the switch is turned on, and vice versa when the switch is turned off. Could the headlamp module be the culprit or has someone had this problem before?
Old Mar 28, 2010 | 08:28 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: Headlight Mystery
sounds like herbie the love bug.......has a mind of his ow.. maybe your car is winking at you!lol I had a friend who had a firechicken that did the same thing, but on both sides.
Gordonr1973
Sep 29, 2015 11:59 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
