can i use a two wire alt on a three wire car how?
I bought the car battery will not charge. It has a two wire alternator on it spliced into the stock three wire clip. The big red wire on the two wire clip is spliced into the big red wire on the stock three wire clip the second wire on the two wire clip is bolted to the back of the alternator(not to the big wire running to the battery, somewhere else on the back). The gauge was working when I drove it home and I watched it slowly drain till it shut off. Can I use this alternator with a little bit of rewiring or should I get a stock one. Thanks any info appreciated? Josh
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: can i use a two wire alt on a three wire car how?
look for a GTO swap thread... he was having a similar issue...
db057
Aug 11, 2015 10:11 PM
