is there a trick to removing these plugs?
Old Apr 1, 2010 | 08:04 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
I'm trying to unplug that bunch of wires that go into that one big plug and the round plug just above with the antenna wires. I already tried but I'm afraid of breaking/ripping the connectors. Any tips? And what's the big one on the bottom called anyway?
Old Apr 2, 2010 | 12:13 AM
bcmag's Avatar
Re: is there a trick to removing these plugs?
not totally sure but usually bulkhead conns bolt together.might have to move wires around to find bolt.
Old Apr 2, 2010 | 12:21 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
that's your ECM harness, have you tried from the inside to see if there is a bolt?
Old Apr 2, 2010 | 06:57 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
X2
Old Apr 2, 2010 | 09:31 AM
Engine: LB9
No I haven't, I'll be sure to check that out. thanks!
Old Apr 2, 2010 | 11:39 AM
Pocket's Avatar
Car: 91 Trans Am
Interior side there is a plastic C-clip. Pop it out and the grommet will come right out. 92s got a small screw at the top along with the C-clip. All other years only had the clip
specialized
Jun 18, 2022 09:26 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Hello, Michael
Aug 20, 2015 03:19 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
