gas gauge or sender unit?
Old Apr 1, 2010 | 08:35 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
My camaro's gas gauge moves but doesn't read correctly if its full it will move about a quarter tank from the full line and when its almost empty it stay around half a tank on the gauge could it be the gas gauge?
Old Apr 2, 2010 | 12:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Engaging Discussion
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the removed sender wire so it can’t short.
Use a potentiometer with a value of 90Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender or wiring going to it.
0Ω = Empty, 90Ω = Full
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
