ignition and interior wiring
Old Apr 7, 2010 | 01:51 PM
thebuffalo's Avatar
Car: 88 trans am
Engine: 350sb
Transmission: t400
Axle/Gears: 7.5/2.73
I just did an engine swap from a 305 tbi to a 1st gen 350. I hooked up my battery to the starter and the power block by the radiator and all my necessary engine sensors are in but there is no power going to the inside of the car. Anyone got any pointers for me?
Old Apr 7, 2010 | 05:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ignition and interior wiring
Did you get the grounds connected from the battery to the engine, and from the engine to the body?
Old Apr 8, 2010 | 11:21 AM
thebuffalo's Avatar
Car: 88 trans am
Engine: 350sb
Transmission: t400
The engine and frame are both grounded good, the starter is wired right too. I'm trying to find a wiring diagram to see if it helps any but I'm not sure its going to
Old Apr 9, 2010 | 12:44 PM
thebuffalo's Avatar
Car: 88 trans am
Engine: 350sb
Transmission: t400
I messed around with the starter wires and put the motor and battery wire on the battery stud and my domelight comes on sometimes but if I hit anything electrical it shorts out, I'm looking through the wiring diagram but I can't seem to find the problem
Ok I fixed the power problem but now when I go to turn the key the ignition is locked up and it won't turn, I have an aftermarket shifter and turbo 400 transmission, thanks if anyone can help
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
penguinpanda0
Aug 15, 2015 06:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
