no power, fuse related?
Old Apr 10, 2010 | 03:20 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
I forgot I had my ECM out of the car and I went to start it (rough night last night) the car didn't even get a full crank and I lost all power (interior lights, horn etc). I plugged the ECM in, checked fuses under the dash, tried resetting by unplugging the battery and still no power throughout the car. Any ideas?
Thanks,
Ted
Old Apr 10, 2010 | 03:51 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: no power, fuse related?
you may have fried a fusible link... I think it's connected at the starter...
Old Apr 10, 2010 | 04:07 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
take a voltmeter set to dc, and test for power to fuse block. and check engine ground on block. report back. and there isnt a fuse-able link for main power block power-if there was it would have to be a high amperage fuse 100amp+, so i dont think its a fuse-able link, the only fusable links i can think of is for the starter, fans and lower load amps.. just test everything to see where the power comes and goes. relays are used here and there check those with key to on position not start
Old Apr 10, 2010 | 06:10 PM
Teds92RS's Avatar
Engine: Lt1
I had power everywhere just not through to the car and the fuseable links on the starter appeared to be OK. Once before I wiggled the harness behind the right fender so I figured what the hell and viola, started right up. I guess I'll be checking that out this week lol Thanks for the suggestions guys.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 13, 2015 12:59 PM
