fusible link maybe?
Old Apr 10, 2010 | 06:27 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
fusible link maybe?
i have an 87 firebird base coup with the 2.8 v6 and the idiot light dash.
the wiring on this car is a nightmare iv been slowly unwrapping miles of electrical tape. and finding numerous electrical splices where a PO had cut and stripped the wires then twisted them together with a shitload of electrical tape. i have fixed most of them with butt connectors and a moderate amount of tape.i didn't know if that was why my gauge lights and shifter light don't work. i have checked the fuses and there all good. so i was wondering if it could be caused by a fusible link and if so where would it be located and how do i check it.
edit: the idiot lights are still working are they on a different circuit
Old Apr 11, 2010 | 08:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: fusible link maybe?
The idiot lights are on the GAUGES fuse, the others on the TAILS fuse. There is a secondary dimmer regulator bolted to the dash frame above the part holding the ALDL and the horn/flasher relays and the buzzer. This can and does go bad. However, if the radio light works, you need to find the problems elsewhere. Also check the dimmer above the light switch to see if it's still working.
Old Apr 12, 2010 | 02:27 PM
87bluebird's Avatar
Transmission: t56
whats aldl and also the radio face stays lit all the time even when the cars off. the radio does get dimmer and brighter if i mess with the dimmer switch. so i don't think its the dimmers switch. the horn flashers and tail lights all work the door buzzer comes and goes. maybe theres a short in one of the wires how would i check for that. i thought i had this car fixed.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
