no tail lights
Old Apr 14, 2010 | 07:01 PM
lg_17's Avatar
no tail lights
I have a 84 Trans Am 305 carburated car. I don't have any tail lights whatsoever. I checked fuses, light bulbs work when head lights are on, but they won't turn on when brake pedal is pressed or when the hazard/turn signals are on. Any ideas? I changed the brake switch behind the pedal but still no go.
Old Apr 15, 2010 | 05:21 PM
severedsanity's Avatar
Re: no tail lights
Pull the the assembly down so you can see the bulbs, take one of the grounds and cut it and then connect it to the metal somewhere to make your own ground for the assembly. I had that problem before and instead of checking every single wire I just did that and problem solved. Good luck, I hope thats all it is.
Old Apr 15, 2010 | 05:26 PM
Stephen's Avatar
Car: 87 GTA
Re: no tail lights
You checked stuff, but did you check the fuses?
Old Apr 15, 2010 | 10:54 PM
lg_17's Avatar
Re: no tail lights
All fuses were good but still went ahead and replaced them. The issue was a pinched wire under the dash that came from the turn signal switch.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
