Incorrect RPM reading on gauge
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Here is my tach issue. I took my 86 IROC Z to a shop. The mech hooked up a Snap On computer in the ALDL port and I read the Idle RPM's at 1,000 on the computer. I looked at the Tach and it read 3,300 RPM's. I couldn't ask the mech to floor it so that I can record at what RPM's the tach would max out at because he too busy. So what approach should I take guyz?
I read the other post relating to the tach and theres good info but I know nothing of electronics. Any help would be much appreciated.
I read the other post relating to the tach and theres good info but I know nothing of electronics. Any help would be much appreciated. Supreme Member
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
RPM Mayhem
There is circuitry in the dash near the tach.
It’s contained on a small plug-in PCB or integrated in the main board.
On the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Because you said you no nothing about electronics you could get a book to show you component identification and definitions, and you should practice soldering on a surplus PCB.
Happy Racing!
I Didn’t Wreck, The Track Moved
Happy Racing!
Re: Incorrect RPM reading on gauge
Hey thanks NINA. Im familiar with soldering, just not the chips and resistors and such. OK, on 4 and 10, Do I solder the resistor directly to the board with the prongs cut and pulled out of the way on the chip?
Transmission: 765R4
RPM Mayhem
Disconnect pins 4 & 10 before soldering the potentiometer or resistor.
You will be soldering the potentiometer or resistor to the board, not the present resistor network.
Happy Racing!
Happy Racing!
Nice! Thanks NINA. Talk to you later.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
