87-88 MAF harness IP connector pinout.
Old Apr 18, 2010 | 09:36 AM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
I need the IP connector pinout for a 87-88 MAF TPI (clear connector on the harness by the ECM). I'm installing the harness in a 86 Monte SS and I am pretty sure they will not match up. From what I researched there are a few I will need to correct, and re route in the SS harness. I have a GM service manual for the SS, but not for the TPI. I can take a few pics of the connector if it will help. Does anyone have this??
Thanks!
Scott.
Old May 7, 2010 | 10:15 AM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Re: 87-88 MAF harness IP connector pinout.
Honestly, I don't understand the silence. I'm a car enthusiast just like the rest here. I've never got this cold shoulder from any other site. What gives with you guys? This system is a thirdgen system. If any one of you needed help, and I had the answer, I would give it to you gladly. Especially if it would save you time and head ache. I would just like the same in return.
Old May 7, 2010 | 02:54 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
read the rules and youll know why you have no response
Old May 7, 2010 | 09:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Might find something here, has gauge wiring diagrams for other years (85/89 )which would be similar
http://www.austinthirdgen.org/mkport...ntents/images/
Why would that be?
Old May 7, 2010 | 09:44 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Old May 8, 2010 | 02:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Would probably help to know what car it came from as the IP connectors may be different... Where it's going doesn't matter as much.
Old May 8, 2010 | 04:52 PM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
So I'll not get a response since the third gen system is not in a third gen....if I hear you correctly. I didn't ask a G body question, I just said I was installing it in the G body.
Since the computer system came from an 88 IROC with a 5 speed, and since they are third generation......then here would be the logical place to ask.
aremy10, if you don't want to help, then don't. I'm not prodding you about this. I just asked an honest question, I'm not looking to spar. If I wanted that, I'd go to another site. I just have a car I'm working on, and need a little help, that's all.
scotrans am
Sep 5, 2015 04:26 AM
middian
Sep 5, 2015 01:42 AM
Billy Decker
Sep 4, 2015 03:46 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
