Sticky gas gauge and jumpy temp gauge
Old Apr 20, 2010 | 11:03 AM
sawyercamaro's Avatar
Car: 86 Z28
Engine: SBC 350 GMPP crate
Axle/Gears: 10 bolt posi
This week I've been removing my carpet to check out the floorboards, and then when I started the car up for a quick ride (gotta stretch those wings!) the gas gauge was stuck past full. Before the carpet removal it had worked perfectly.
Also, my temp gauge will jump around in the lower temp range while the car is running. This problem is not so big, because I have an external set of gauges mounted under the dash that show Temp, Oil, and Battery.
I figure the gas gauge is just a grounding issue caused by me when I moved something trying to get the carpet out.
I do have a DVOM and some electrical knowledge, but if anyone has a good place to start, that would be awesome.
Old Apr 20, 2010 | 02:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bad Car Pet
There is no common ground under the carpet for the gages.
You might have disconnected the line from the sender to the fuel gage.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Apr 22, 2010 | 04:31 PM
Car: 86 Z28
Re: Sticky gas gauge and jumpy temp gauge
Strangest thing ever, I started the car up today and the fuel gage went to its accurate position (Only ever fill it with 1/4 tank). Strange, but atleast it's back to normal, for now. Would that imply a short or the float being stuck?
Old Apr 26, 2010 | 09:22 AM
NINÅ's Avatar
Transmission: 765R4
Whatever Floats The Float
The float might have been stuck due to an unknown problem.
Next time it happens try some high-G turns, and high acceleration followed by impending lockup braking.
If that “fixes” it you should take a look at or replace the float.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Reddeath210
Oct 6, 2015 08:20 AM
Papaginos
Sep 27, 2015 03:29 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
355sbcTPI
Aug 19, 2015 04:38 PM
