Getting 12v to coil with ignition on but loose it at start position??
Old Apr 21, 2010 | 01:53 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I've searched and no luck. I have a carbed 350 that was running fine in my DD Formula 350. Switched engine into a 88 trans am and got wiring hooked up and try to start it up but nothing. I checked the PINK coil wire and I'm getting 12v but I loose it when I try to start the car. There is a white wire with a connector at the end next to the pink wire and I'm curious if this has anything to do with it?
Any help would be greatly appreciated!!
Old Apr 21, 2010 | 03:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Check Twice Cut Once
Did you check the C side and the + side of the primary?
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
89GTAOz
May 16, 2020 09:31 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
