Will any of the wiring harnesses......
Old Apr 21, 2010 | 07:45 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Transmission: TH400 and 6 speed
Axle/Gears: 12 bolt 4.11 and posi 3.73
from the GM lineup of V6 cars in the late 80s contain the connectors to build my own TPI harness. I have access to a junk yard with plenty of them. I read somewhere that a V6 ECU can be used as one for TPI sans the prom. I would really hate to shell out for an expensive Painless(not to my wallet) wiring harness when I could basically get one for free.
Old Apr 22, 2010 | 08:09 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Will any of the wiring harnesses......
New aftermarket TPI harnesses can be had for around $200. If thats too much, then yes, you can assemble a harness from JY connectors. Read my thread about building LS1 harnesses to see how its done
A simpler route would be to find a complete 90-92 V6 harness and modify it. From an ECM and control point of view, V6 and TPI are nearly identical
Old Apr 22, 2010 | 06:29 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Which after market harness goes for $200? The only ones I have seen are in the $400 dollar range. Thanks for confirming my suspicions on the V6 harness compatibility.
Old Apr 22, 2010 | 06:33 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The V-6 harness is a lot longer than the V-8 so it will require a lot of shortening of the wires, but with a few changes it will work.
One thing to note, the ac fan set up is different (if you care).
I have done a few.
Old Apr 22, 2010 | 07:20 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
I have done a few.
How or can you add the 2 additional injector wires (4 total) to make it V8 from V6 without totally dismantling the V6 harness? I forgot to add that I have a 86 305 TPI unit that I plan on swapping in 22lb injectors and using a common HEI distributer with modded connecter going onto a 60s small block driven by a non computer 700r4.
Old Apr 22, 2010 | 08:16 PM
Pocket's Avatar
Car: 91 Trans Am
I dont feel like typing the whole explanation out for a 4th time today so Ill let the diagrams do the talking
http://www.austinthirdgen.org/mkport..._injectors.jpg
Use your old TBI distributor
All 700R4s are non CC'd. Same with 4L60's
Computer controlled transmissions didnt come around until the E class trans were introduced. For Fbodys, this was 94
Old Apr 22, 2010 | 08:29 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Sorry Pocket, I'm new to this this type of injection system and could'nt find your thread on building a harness. Again please forgive my lack understanding and thanks for the info!
Old Apr 22, 2010 | 08:38 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Sorry Pocket, please forgive my lack of knowledge of this type of injection system. I'm not sure which direction to go in and don't look forward to paying for a costly mistake should one happen. Could'nt find your thread on building a harness. Thank you for the info.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
