Ignition Coil Question!!
Old Apr 25, 2010 | 11:38 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I'm wanting a new coil, but I'm confused about the remote coil versus the drop in coil.
Which MSD part number is the "drop in" direct replacement coil? I'd prefer that over a remote coil.
If both are msd upgraded coils, then what's the difference in performance?
Is the remote coil better, in some way, than the drop in replacement?
Thanks to any who can help.
Old Apr 25, 2010 | 11:47 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Ignition Coil Question!!
Remote meens mounted away from the dist. and drop in is for the coil in the cap of the dist.
Old Apr 25, 2010 | 12:28 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I meant is there a performance advantage of one over the other.
Old Apr 25, 2010 | 12:33 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Not that I'm aware of . It just depends on your coil setup .
Old Apr 25, 2010 | 02:56 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I was wondering why a guy would go through the trouble of a remote coil, as opposed to just dropping in an upgraded one quickly and easily. It makes me think the remote coil has some distinct advantage over the drop in coil.
Old Apr 25, 2010 | 06:54 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
bump
Old Apr 25, 2010 | 08:14 PM
S-chargedIroc's Avatar
Car: 1987 IROC Z
Engine: L98 350
I am in the same situation actually as I am dropping in a remote MSD coil while hooking up my 6BTM box...There are small performance increases in the remote coils. The best way to check is going to the technical specs on the official MSD web site. Either way you go, it is a much more effective coil then the factory setup in my opinion.
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
