what are these connectors (center console area)
Old Apr 26, 2010 | 06:26 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
any ideas?
my car does not have power seats, windows, defrost, hatch release, power mirrors, door locks. maybe it's for one of these?
manual transmission.
trying to figure out if i can use one of these for connecting 4th gen power seats.
Attached Thumbnails what are these connectors (center console area)-connector-1.jpg   what are these connectors (center console area)-connector-2.jpg
Old Apr 26, 2010 | 07:31 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: what are these connectors (center console area)
Connector 2 is for the neutral safety switch, which incorporates back-up lights as well - you'll need it, so don't mess with it.
4th gen power seats are easy - just run a wire with an inline fuse from any empty slot in the fusebox, under the kick panel, under the carpet, out under the seat belt retractor, and up to the seat. Then, ground anywhere under the seat to the body - I attached my ground to a screw I put into the metal brace that holds the seat belt retractor.
Old Apr 26, 2010 | 07:41 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
would that conntector 2 only apply to automatic transmission? i don't think that piece has ever been connected in my car.
Old Apr 26, 2010 | 08:00 PM
Car: 1992 RS
Engine: Carbed 350
Maybe - it looks like mine (which is an auto) - but there has to be soe kind of safety switch in a manual car I would think - maybe a clutch safety switch on the clutch pedal - and there would be some sort of wiring at the gear shift for reverse lights.
See if anything on that connector 2 has 12v, and tap into it if it's easier for you.
The wire I ran from the fusebox I plugged into an empty BATT slot with a standard spade connector - that way I can adjust the power seat without having the key on, like when the short wife drives and doesn't return the seat back I can't get in to turn the key on, or when I'm vacuuming at the car wash I don't have to have the key on.
Old Apr 26, 2010 | 11:20 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
For the seats, I'll run the wire as you recommended. Still curious as to what those other connectors are for.
I started thinking the 2pin (connector 1 image) is for power seat option. It's getting 12v across them, but I think the wires are too thin too handle the current draw.
Old Apr 30, 2010 | 04:03 PM
Pocket's Avatar
Car: 91 Trans Am
The large 6 pin connector goes to the automatic shifter. Strange you have it in a manual car. Leave it alone unless you have trouble starting the car or your backup lights are in-op
Orn/blk 2 pin connector is for your console light. Some cars didnt have this and the connector was left unplugged from the factory
The other small 2 pin connector should have a tiny light in the tip of the socket. It lit up your gear map on your shift plate
Wiring your power seats to battery 12v instead of IGN 12v is a great idea. I did so by accident several years back before I knew the difference when I installed power seats from a 2000. Much easier to clean the car
Old Apr 30, 2010 | 04:05 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
thanks.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Firebird sweden
Aug 16, 2015 05:02 PM
