Engine elcetrical glitch - HELP
Old Apr 29, 2010 | 03:23 PM
ZEXY's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: TPI 350
Transmission: Brog-warner 5 speed
Axle/Gears: Borg-Warner 9 bolt 3.45 posi
I have an 88 forumla Firebird its got a TPI 350 with a 5 speed.
When its running everything seems normal nothing out of the ordinary. When i put an load on the engine weather it be i just rev it up or try to drive through a red light like a grandma, or take a corner this glitch happens. I thought maybe it was the battery terminals so i cleaned them. Didnt fix it so i need some help.
Things that happen when the glitch comes
Voltage gauge drives to right around 11 or 12
oil pressure gauge drops to about 10 or 15 pounds when normaly at 50
Radio shuts off and then turns right back on speakers and subwoofer pop and sputter
The engine it self doesnt sputter or die even when WOT or anywere inbetween. The gauges go right back to normal after the car settles like there are no G-Forces.
So any help on this would be great this is my daily driver so kinda need it quick
Old Apr 29, 2010 | 08:18 PM
bcmag's Avatar
Re: Engine elcetrical glitch - HELP
check your body ground first.
Old Apr 29, 2010 | 08:41 PM
ZEXY's Avatar
Engine: TPI 350
That would be the wire from the negetive terminal to the car body i would assume?
Old Apr 29, 2010 | 09:48 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Also from the back of the passenger side head, to the firewall.
Old May 1, 2010 | 08:44 AM
ZEXY's Avatar
Engine: TPI 350
Well things seem back to normal. Thanks for the help
Old May 3, 2010 | 04:46 PM
Pocket's Avatar
Car: 91 Trans Am
Have the alt tested then check grounds
Wiring issues dont magically fix themselves. Low volage on the gauge suggests charging/battery issues
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
