tach dont work help
Old Apr 30, 2010 | 12:38 AM
91maroRS91's Avatar
Car: 1991 Camaro RS, 1987 Firebird
Engine: 305 TBI, 350 TPI
Transmission: 5 Speed, Auto
Axle/Gears: N/A someoone tell me
tach dont work help
my tach in my 1991 camaro rs does not work. sometimes when i start the car right as the engine cranks over the tach works but once the enigine gets running it just drops to the red line and obivislously thats not how its actually ideling. someone give me some suggestions on what could be wrong and how to fix it.
Old Apr 30, 2010 | 06:41 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: tach dont work help
i would ohm the wire from the distributor to the gauge cluster, then ohm the grounds, check the connections at the gauge, if all checks good i would try another gauge. i have a similar problem but only when i turn my lights on so its likely a bad connection somewhere.
Old Apr 30, 2010 | 04:00 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
A search would have taken you to this post.
https://www.thirdgen.org/forums/elec...meter-fix.html
Old May 2, 2010 | 08:46 AM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
Go to the junkyard and pick up a old tack pull your instrument cluster and exchange
it. If it works you've nailed the problem.
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
