New problem with gauges, tach
Old May 3, 2010 | 12:14 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
I'll preface this by saying I appreciate everyone that provides great information everytime I have a problem. Hopefully, I can learn enough to help a few others out eventually.
That said, my battery guage is dead at 0, the tach does not move and stays at approximately 800rpm, oil pressure gauge shows about 2 lb., and the fuel guage is doing it's own thing from moment to moment. Speedometer and odometer are working properly it appears.
This started after a distributor rebuild and retiming recently. I know the tach used to be reliable, but have always questioned the temp gauge, fuel gauge, battery gauge. I just installed a new fuel pump and the fuel gauge used to work, although it would hang at full sometimes.
Where do I begin chasing this gremlin?
Old May 3, 2010 | 01:58 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Ground To A Halt
You might have a ground that came loose at or near the dash connectors.
With an ohmmeter you can trace the ground.
Or sometimes the dash circuit board develops a crack causing similar problems.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
