no speedo after carb swap
Old May 4, 2010 | 12:54 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I took the ecm completly out (was a 305 tpi) and I can't get my speedo to work, I read something about a buffer box on here, what exactly is that?
I have a TCC switch that uses the VSS, so I assume it will run the speedo if I connect it to the original wires so I need to know what color the original wires running to the speedo in the dash are (my haynes manual says brown and black/white but none of those seemed to work)
thanks, Tim
Old May 4, 2010 | 03:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Buff It Out
The buffer looks like this.
It should be located near the ECM.
On some thirdgens it’s behind the dash.
Different years/models used different wire colors.
You can probe the buffer with an audio amplifier.
The line with the higher pitch goes to the speedo.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Jorlain
Aug 24, 2022 05:11 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
