headlights!?!
Old May 5, 2010 | 03:13 AM
nastynate6's Avatar
Car: 1991 camaro rs. 1992 camaro z28
Engine: 3.1 liters/V6. & 305 v8
Transmission: automatic
headlights!?!
i bought my car about a month ago and the fuse box is hanging from its wires because the mount is broken.
im not sure if the headlight is broken or if its just a fuse?
i dnt knw much about cars but i dnt want to pay someone for an easy fix.
could it be a bad fuse(what kind of fuse do i need?), a loose wire, broken headlight!?!
the highbeams and the fog lights work just not the low beams.
Old May 5, 2010 | 11:05 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Head In The Light Direction
The headlights use no fuses in the fuse block.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the pull-for-on switch.
With the switch extended see if you have power at the
red wire.
If yes, see if you have power at the
yellow wire.
Is there power both places?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
