1986 Firebird Gauge Cluster Question
Old May 13, 2010 | 06:40 PM
Keegancw's Avatar
I apologize for my lack of knowledge on this subject....
Okay, I have been searching around and have not been able to find the answers to any of my questions.
I have a base model 1986 Firebird (2.8L V6) with a 2 gauge setup (with all of the circles with lights to the side of it), and would like to switch to the 4 gauge setup with the tachometer and temperature sensor.
I read that all gauge clusters 1986 and newer are electronic, except for the 1986 V6 models. Is this correct?
Are they a direct swap if I find one of similar year (1985-86?)
Are there usually wires already there for the tachometer\temperature sensor?
Since there are a lot of random lights to the side of my current gauge cluster (For example, the check engine light, e-brake, etc,) are there inputs for these in the 4 gauge cluster?
And lastly, has anybody done this themselves? If so, could you please give me more information about how you did it.
Again, I apologize for my lack of knowledge on this subject.
Old May 16, 2010 | 04:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1986 Firebird Gauge Cluster Question
im not sure with the electronic/mechanical speedo, but AFAIK, the pods will all interchange, you may have to change the dash panel if you go to the 4 round gauge style pod
Old May 17, 2010 | 05:11 PM
Keegancw's Avatar
Okay, thank you. Does anybody know about the mechanical\electronic information? What would I need to make an electronic speedometer work?
Old May 17, 2010 | 05:30 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Check this out...
http://www.hioutput.com/tech/speedo.html
Old May 17, 2010 | 07:14 PM
Keegancw's Avatar
Originally Posted by Jupiter
Thank you very much. This helps a ton.
Old Nov 9, 2010 | 08:37 AM
MACproWIZ's Avatar
Car: 1986 Pontiac Firebird
Engine: 2.8Lt V6
Transmission: 4 Speed Automatic
I am sort of looking at this question but from a different angle. I also have a base 86 firebird 2.8l v6 but I have the 4 gauge setup, and want to know if I can use the electronic circuit boards, and make make dash into digial readout with LEDs and such... a.k.a - KITT.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
