fuel guage?
Old May 21, 2010 | 08:41 AM
camedout camaro's Avatar
fuel guage?
i have a 91 camaro that i droped a carb 350 into i was wondering if anyone could help me out as to how the fuel gauge works. will it work with out the wiring harness? and if not is there an esay fix just to see how much gas i have? thanks for the help.
Old May 21, 2010 | 09:13 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel guage?
All of the guages should work fine in your car as long as all you disturbed was the pass side wiring harness.
Old May 21, 2010 | 05:46 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: fuel guage?
Correct, all the gauges will work if you started with a TBI car that has the VSS buffer box. If not they will all work except the speedo. That is also assuming you hooked up the stock water temp and oil pressure senders on the engine right.
Old May 22, 2010 | 08:40 AM
Re: fuel guage?
no i used all my own gauges and sending units. this is my first build so it is kinda ghetto rigged. and the guy who owned the car before me was planning on making it a dirt track car. so idk what he cut out but i had to run my own power to the fuel pump and run another tach and water/oil sending units so idk what he did to mess it up but it does no work. so if there is anyone who knows how to run one from scrath please help me out thanks.
Old May 22, 2010 | 12:24 PM
travis401's Avatar
Car: 91 Camaro RS
Re: fuel guage?
Im guessing he dropped in the motor thats in it? This might help figure out the wiring under the hood. https://www.thirdgen.org/forums/ltx-lsx/541387-how-prep-3rd-gen.html
If the PO hacked up the dash wiring, it will probably be easier to replace the whole thing than trying to figure out what he cut/changed around. [IMG]file:///C:/Users/LeX/AppData/Local/Temp/moz-screenshot.png[/IMG]
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
