distributor help!!!!!!
Old May 25, 2010 | 01:48 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
converting my buddies 84 camaro hei distributor to the distributor with an ignition coil
does anyone possibly know what is required to do this, i have everything from my old 305 tbi but im putting the distributor on the camaros carbed 305.
so far i got the distributor in and the ignition coil bolted to intake but what do i do next? does the wires have to be spliced into something else?
somebobdy please help me!!!!!! this car is driving me insane
Old May 25, 2010 | 02:02 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: distributor help!!!!!!
I may be mistaking, but isn't the TBI distributor partially computer controlled? I don't believe it will work on a carbureted engine. You will need an HEI unit, with vacuum advance, depending on whether your using an aftermarket carb or not.
Old May 25, 2010 | 02:04 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
yeah i have pretty much everything needed for it to work i just need to know how to make it work, the cam is stock and the carb is the stock quadrajet. ever since intake swap this pos never wants to start back up
Old May 25, 2010 | 02:16 PM
What mods all have been done? The stock quadrajet will need the stock computer controlled HEI distributor in order to function properly. I don't believe a TBI distributor (with the external coil) will work properly, and if you use an HEI vac-advance distributor, the carburetor won't function properly. You need both pieces in order for it to function properly.
Double check your firing order, and ensure your not 180* out.
Old May 25, 2010 | 02:30 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
were putting a holley double pumper on there, the problem with the old distributor is its busted to **** and the wires are all cut and pulled. he just bought it last week and we finally got to working on it last sunday and then again today
Old May 25, 2010 | 03:05 PM
Okay than.
The Rochester will only work with a stock cc distributor that it came with from the factory.
The holley wont work with the factory distributor, and I am pretty sure it wont work woth the TBI unit either. Get an HEI with vacuum advance.
Old May 25, 2010 | 03:08 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Okay than.
oh ok so either way we will need a new distributor?
what about all the missing wires that went to distributor originally? what do i do about them when we replace the distributor?
Old May 25, 2010 | 05:59 PM
A vacuum advance distributor really only needs one wire, and thats the IGN wire (a thick pink wire) to run. The tachometer wire should be a white wire, and hooks to the 'TACH' terminal on the distributor, if you have a tach.
If you keep the rochester, get a good used distributor from an LG4 (305 carb'd motor) that had an electronic carb, so they will work together.
If you plan on using a holley, than get a vacuum advance distributor, but stay away from the chinese ones on eBay, I got one and it didnt work at all. I bought an MSD Streetfire distributor from summit, popped it in my motor, and it fired the first try, just goes to show that quality matters.
Although, I dont want to tell you to go buy a new distributor, as I am not sure if the TBI one that you have can be modified to work without actually having a TBI unit. I am, however quite sure that it will not work with the holley.
Old May 26, 2010 | 12:48 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
The TBI dizzy wont work, it was computer controlled. Like stated before, youll need an HEI dizzy. It only needs a switched 12v source to work, and a wire for the tach if you have one.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
