Starting issues
Old May 29, 2010 | 10:59 AM
chev2fast4u's Avatar
Car: Two 91 Z28's
Engine: Both 305's one Supercharged
Transmission: T-5 and Auto
Starting issues
Ok well I've had my car in storage for a few yrs and went to get it out. It started up fine once I put in the new battery. It was running really rough but worked. I towed it closer to home and it started up again running rough. So I disconnected the temp sensor and low and behold the car ran like a top. So I figured I needed a new temp sensor and was good to go. Left the car overnight and came back and car would not start at all. I decided to change the spark plugs and then tried starting it up again but I have no spark and probably didn't the first time after sitting for the night.
I then replaced the distributor cap and rotor and also the coil but to no avail I have no spark. Any suggestions as to what might cause it to have no spark. I'm thinking a corroded wire or starter wire or maybe computer???? Any input would be appreciated.
Old May 30, 2010 | 09:00 AM
timonator's Avatar
Re: Starting issues
Maybe the ignition control module.
Old May 30, 2010 | 09:23 AM
Car: Two 91 Z28's
Re: Starting issues
nope just put in another last night still no spark
Old Jun 2, 2010 | 11:23 AM
NINĊ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Spark Of An Idea
Disconnect the 4 terminal connector at the distributor.
Is there any spark now?
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Jun 3, 2010 | 06:36 AM
Car: Two 91 Z28's
Re: Spark Of An Idea
found the problem the distributor itself was bad. THanks for all the help.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
