name that connector !
Old Jun 1, 2010 | 08:59 PM
Gecz28's Avatar
Car: 88 iroc vert
i have 2 connectors on the column i have no idea what they are or where they go???
sorry for the quality, cell pics
the first 1 is the white connector and the 2nd has 1 wire coming out, seems like its plastic?
if anyone knows what the first one is, do you have the pinout for it?
Old Jun 1, 2010 | 09:07 PM
Gecz28's Avatar
Car: 88 iroc vert
Re: name that connector !
i have a 88 vert i gutted. i got a painless wiring harness and trying to figure what to hook up to what?
i dont want heat, a/c, wipers so rather than cutting the wires out, i just got a hew harness and ill tuck the wires under the dash. i wanted to eliminate all the relays and other crap from under the hood so it looks clean and simple. pop the hood and just see an engine.
Old Jun 1, 2010 | 10:07 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
I think the black connector is the one that plugs into the harness on top of the steering column. I think that's what connects your steering wheel functions into the car, such as turn signals, hazards, and so on.
Old Jun 1, 2010 | 10:43 PM
Gecz28's Avatar
Car: 88 iroc vert
yea the black does the turn signals, hazards and the horn
i m not sure but i would think the white connector would have to control the ignition? not sure what wires are what???
Old Jun 9, 2010 | 08:41 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
the white one should be for your winshield wipers
Old Jun 9, 2010 | 09:09 AM
Pocket's Avatar
Car: 91 Trans Am
Big one is wipers, small cruise control from the stalk
Theres actually 4 tiny wires under the black sheath
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
