Almost Done with the TBI to TPI swap. Have a wiring Harness Question!
Old Jun 4, 2010 | 04:22 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
ok so I am installing an 89 TPI system using an 88 TPI Harness in my 90 TBI camaro. I was told that even though the harness will plug into the firewall with no problems there will be some problems with things working because the circuits could be different. And I will need to pinout something. IS this true and what is a Pinout
Old Jun 4, 2010 | 06:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Almost Done with the TBI to TPI swap. Have a wiring Harness Question!
A pinout is a "plan" for want of a better word that shows what wires go where.
Here is ECM pinout for '165 ECM used in '86 - '89 TPI cars
http://www.chevythunder.com/198689_f...dy_1227165.htm
Also good to compare the engine wiring differences between the two setups
88 TPI
http://www.austinthirdgen.org/mkport...ine_wiring.gif
'90 TBI
Old Jun 4, 2010 | 06:59 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
these diagrams are for the ECM right?. i was lookin for where it goes into the firewall on the drivers side.
There would be no problems with plugging an 89 ECM into an 88 Harness on the pass side right?
Old Jun 5, 2010 | 12:00 PM
Pocket's Avatar
Car: 91 Trans Am
86-89 ECMs are interchangeable
MustangBeater20
Oct 29, 2022 09:20 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
