91 tbi to carb electrical wiring help please help
Old Jun 5, 2010 | 01:39 PM
johnlea's Avatar
I know this has been addressed be fore but I just ned the basics.I do own a 91 Camaro but this has to do with my 91 1500 305.
Hears where i"m at.
Holley 600 and matching intake
The engine is a stock 400 sb
Return reg
Accel hei
Proper brackets
And all the odds and ends
I have read numerous articles about wire the fuel pump this way or that way.
I trust you guys and all I'm looking for is the simplest way to get this thing running.Some of the wire colors don't seem to match what has been posted.
Nothing fancy.Wiring is my weakness.
Please help
John
Please
Old Jun 6, 2010 | 04:14 AM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
Re: 91 tbi to carb electrical wiring help please help
are u gona use the stock fuel pump or an aftermarket?
Old Jun 6, 2010 | 06:35 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Jun 7, 2010 | 01:08 AM
johnlea's Avatar
In tank tbi pump
Old Jun 8, 2010 | 02:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by johnlea
In tank tbi pump
All you need a wire that is hot ; key on , to power up the stock TBI pump relay.
That way you don't have to think about turning off / on a seperate pump switch.
You should have a suitable wire left on your stock TBI harness ; ones that used to go to emissions stuff especially
Use a DVM to find a unused wire that has 12V on it when the key is turned ON and run that to the relay replacing the wire that used to run to the computer to operate the relay
Old Jun 10, 2010 | 06:08 PM
johnlea's Avatar
Just a little confused.Do I send the wire to the switch on relay plug wires or to the relay with the plug installed to the relay?
I guess what I'm askin is do I bypass the relay and connect to the plug or brek the box covering the relay and keep it hooked up.
Thanks so much for your help
Old Jun 12, 2010 | 09:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The relay used to be operated by the computer.You just run a replacement wire to operate the relay leaving it in place
Just cut the old wire at relay plug and join new one to it
Typical GM relay wiring shown below.
You need key on 12V to green/ white wire or whatever wire on your TBI relay that went to the computer
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
tero
Aug 15, 2015 02:47 PM
