drivers signal ground
Old Jun 7, 2010 | 12:28 AM
billyhoss's Avatar
does anyone know where the ground is for the drivers side signal light and is the fog lights grounded at the same spot? its been raining for days here and now the fog lights and the drivers side signal cut in and out and i can hear a clicking from under the dash, thinking that its a grounding problem.
Old Jun 7, 2010 | 12:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Left Alone In A Fog
If the all the left hazard lamps work the grounds are good.
Anyway the left front turn signal lamp ground is located behind the left headlights.
The left fog lamp ground is located behind the left headlights.
The right fog lamp ground is located behind the right headlights.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jun 7, 2010 | 02:51 PM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
Re: drivers signal ground
It may also be the turn signal flasher, about 7-10 dollars at an auto parts store
Old Jun 7, 2010 | 02:59 PM
billyhoss's Avatar
i though about the flasher also but figured what would it have to do with the fog lights also. i recently changed the bulbs in the front signals so i changed them again with new ones and put dielectric grease in then this time since i noticed alittle moisture around the bulb and so far no more problems. so i will see if that did it.
LittleFranks
Sep 17, 2015 12:22 PM
dibella989
Sep 1, 2015 04:12 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
hepcat620
Exterior Parts Wanted
Aug 30, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
