Firebird fuel pump
Old Jun 14, 2010 | 12:48 PM
jartza's Avatar
Car: Firebird
Transmission: TH350
Axle/Gears: 3,74
Firebird fuel pump
Firebird -83 has originally been V6. It is modified (by previous owner) to V8 (350 engine).
Fuel in pumped by electrical pump. Pump is powered by direct voltage thru iginition key. I'am worried about direct voltage .
I would like to re-wire fuel pump wiring thru relay. Is the original V6 equipped by relay? Wiring diagrams would help.
Please advice.
Old Jun 14, 2010 | 12:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Firebird fuel pump
Use a 7psi oil pressure switch inline, so the pump doesn't work unless you have atleast that much oil PSI. Yes it won't start right away, will have to crank for a sec, but is better for the engine to not start till ya have oil PSI n e ways.
Plus if you ever wreck, it will shut off if the engine dies.
So it not just pumping fuel.
The switch was used on all of the FI 3rd gens, easy to find, even on ebay fpr cheap.
Old Jun 14, 2010 | 01:02 PM
jartza's Avatar
Car: Firebird
Transmission: TH350
Axle/Gears: 3,74
Thanks! I try to find the switch.
Old Jun 14, 2010 | 01:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Dunno if it will help, I got one off ebay a while back for like $7 but you can find ones that cost much more.
Filko
OP-86X
oil pres, sw.
Old Jun 15, 2010 | 02:52 AM
jartza's Avatar
Car: Firebird
Transmission: TH350
Axle/Gears: 3,74
I would like to clarify...
Is the oil pressure switch additional? So I'll keep the oil pressure sensor, which gives values to gauge?
Does 350 block have place for the switch.
Thanks!
Old Jun 15, 2010 | 11:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thanks!
yes to all, you can find oil port all over the place, though note that the block just uses standard NPT [national pipe thread] so if you stuck you can just visit the HW store and with some small plumbing fittings make a T connection to plug 2 parts in 1 hole, or extend a hole.................
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
