1982-86 FIREBIRD HEADLIGHT DORR RELAY INFO.
Old Jun 15, 2010 | 12:44 PM
HutchBMX's Avatar
OK a friend has a couple T/A's and we were cleaning up and detailing some headlight issues.
Here is the info. I accumulated.
RELAYS:
1982-83
1 ISO RELAY (10038949) located on core support with a bracket that snaps into relay body (actual placement on core support unknown)
2 MOTOR RELAYS (10041733) located next to ea. headlight assembly held in place by a bracket that goes around (cradles) the relay (actual placement unknown)
1984-85
2 MOTOR RELAYS (10031246) located on inner fenders LH & RH held to inner fenders with a bracket that snaps into relay body (actual placement unknown)
1986
1 ISO RELAY (10022620) ?????? somebody fill this in
last replacement part info. from GM
1982-86 ISO RELAY (10022620) has a "T" shaped bracket with 2 mounting screw holes snapped into relay
1982-86 MOTOR RELAYS (10031018) relay only, no bracket as was necessary for the 1984-86 application
MOTORS:
1982-86 used the 3 wire motor
If you guys could fill in the stuff I missed and post pictures of the relays showing detail of their mounting locations (include year of car), it would help us all out with troubleshooting and parts locating.
1987 and later used a module in place of the relay system and a 2 wire motor.
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
