Fuel pump power wire location
Hey everyone, im in the middle of my lt1 swap, she runs on ether!!! but we cant figure out which body wire is the one for the fuel pump, Ive attached a pic of the trunks on the pass, and drivers side, its an 88 v6 originally...
which wire is it?
anyone have a diagram?
if its not in these pics, can u identify??
thanks so much
which wire is it?
thanks so much
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuelish Questions
The fuel pump wire is the 16 AWG gray one.
Once you get a hold of it you can trace it to verify it going to pin E of the fuel pump relay.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Happy Racing!
Re: Fuelish Questions
thank you,
we had foolishly cut the 3rd gen harness early, does anyone know the location of the wires.. relay back inside the firewall? we are trying to find the wires in the firewall/interior of the car,
thank you!
thank you!
Re: Fuel pump power wire location
1) Remove the harness from the car before modifying it. It makes life 300x easier
2) As posted in your LTx/LSx thread its C100 pin G4, TAN/WHT. It didnt turn GRY until 90
3) What is that block in the first pic? Its not from the 3rd gen
4) The fuel relay is mounted near the brake booster for 3rd gen, not inside the car. Its the same pin for both the engine side and dash side of the C100. If it wasnt, they would never connect
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
