Turn Signal Cross Short?
Old Jun 20, 2010 | 10:21 PM
RyanEricW's Avatar
So....when I go to use either turn signal nothing blinks. I am pretty sure it is a cross short and wondering if it is a common problem before I go tracing wires.
I turn on the right signal.
- Right arrow stays solid on dash.
- Passenger front stays solid outside.
- Passenger rear stays solid outside.
I turn on the left signal.
- Left arrow stays solid on dash.
- Driver rear stays solid outside.
I laughed when I seen this...
Haven't looked at anything yet, but my first guess is perhaps a wrong bulb in one of the turning lights. Second guess is a grazed/+ shorted wire. Third would have to be the selector switch.
Let me know if anyone has encountered this before, but either way, I will provide a solution for those in the future in case they have a similar problem.
Thanks!
Old Jun 20, 2010 | 10:58 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
Re: Turn Signal Cross Short?
change both ur blinker cylinoids.
Old Jun 20, 2010 | 11:00 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
its liek a silver thing its the shape of a cylinder and its silver youll see it, its under the steering colum. there are 2. one it clipped next to the fuse box and one is bushed up kinda by the seering wheel right next to two 15a fuses
Old Jun 20, 2010 | 11:03 PM
RyanEricW's Avatar
LOL thanks for the fast reply!
Really think it's the flashers? =)
Thanks!
Old Jun 21, 2010 | 10:20 PM
RyanEricW's Avatar
I changed both of the flashers today, while under the dash there was one to the right in a fuse like box, and another by the steering column.
I'm not sure what the one in the fuse box does, and although it was a different number flasher, I bought two new flashers that were the same number as the closer to the steering column that used a connector.
I still have the same problem though. Seems like the two fronts are crossshorted as the right front always stays illuminated while the lights are on for the car. The rear turning lights do work though. Weird
Prodigious
Nov 7, 2020 09:23 AM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
