lt1 questions
Old Jun 21, 2010 | 05:27 PM
Datsun570Z's Avatar
lt1 questions
Not sure if this is in the right place so admins please move if needed.
I picked up a 94 lt1 out of a Z28. It came with everything minus the wiring harness. I was able to get ahold of a Custom made harness with a chipped ECU and VATS removed. Only problem is that the harness does not have the MAF connector. With that being said it leads me to think that it is for the 93 lt1.
My question is do I need the MAF connector and are there any other differences electrically that I need to be aware of?
If needed I would be willing to trade the harness and "chipped" ecu for a 94 harness.
the motor is going into a 1976 280Z with a t-5 tranny to back it up.
Old Jun 22, 2010 | 08:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: lt1 questions
Originally Posted by Datsun570Z
I was able to get a hold of a Custom made harness with a chipped ECU and VATS removed. Only problem is that the harness does not have the MAF connector. With that being said it leads me to think that it is for the 93 lt1.
What does ECM look like ?
'94 + PCM are cast alum case that is mounted in engine bay and don't have a removable chip in them
As the '93 didn't use a MAF sensor you should be right if ECM / harness is from a 93
Old Jun 22, 2010 | 05:26 PM
Datsun570Z's Avatar
Re: lt1 questions
Yes both are from a 93. I have the 94 as well so I'll prob just sell/give it away to some one who could use it.
Old Jun 23, 2010 | 03:00 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: lt1 questions
Yes both are from a 93..
some reading
http://www.chevythunder.com/lt1_electrical_page.htm
http://www.chevythunder.com/199394_l...tic_page_1.htm
Old Jun 23, 2010 | 05:04 PM
Datsun570Z's Avatar
Re: lt1 questions
Wow thanks for the info much appreciated.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
