Fog Lights
Old Jun 24, 2010 | 12:21 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Fog Lights
Ever since I bought my car my fog lights had not worked. I replaced alot of the fuses and they still dont. Is it possible that I just need to replace the bulbs (is that possible?) or would I have to replace the whole light? Or could it be something else?
Old Jun 24, 2010 | 01:02 PM
Stephen's Avatar
Car: 87 GTA
Re: Fog Lights
Could be a fuse...relay....switch....bulb....bad wire....connection. The relay might be the easiest to reach, check & determine which direction to go in the circuit to start looking for problems.
Old Jun 24, 2010 | 02:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fog Lights
The following may not be helpful at all, but FWIW, from 86-on, Camaro fog lights work with parking lights on and with low beams on. They won't work with high beams.
JamesC
Old Jun 24, 2010 | 02:05 PM
Stephen's Avatar
Car: 87 GTA
Re: Fog Lights
JamesC
Oh yeah....Been so long since I "fixed" mine, I forgot about that. Mine stay on even with the High Beams now.
Fog Lights w/High Beams "fix" mod
Old Jun 24, 2010 | 02:24 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
Re: Fog Lights
Originally Posted by '87IROCZOWNER69
]Is it possible that I just need to replace the bulbs (is that possible?) or would I have to replace the whole light? Or could it be something else?
You should change out the bulb, it might be as easy as that, when I got my T/A, neither of the fog lights worked, I changed out the bulbs and that did the trick... they were way over due for getting changed out.
Old Jun 24, 2010 | 04:01 PM
Re: Fog Lights
Is the size of the bulb I need written on the light or does one of you have an idea of the size I need.
Old Jun 24, 2010 | 11:46 PM
LTL_DMON's Avatar
Car: 1986 Trans AM
Re: Fog Lights
The number you want is 885, however it looks like it not available... you could get the 893. This thread should help...
https://www.thirdgen.org/forums/auto...og-lights.html
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
