random gauge light coming on
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
I finally got around to testing the electrical system in my 92 camaro (vin E) prior to dropping the lt1 in, and when I did, I found that I have no voltage going to the starter from the ignition switch and the gauge light under the spedo, fuel, and oil pressure gauges started coming on with the key. Funny thing is, it goes off when i turn on the headlights. the rest of the lights still work right. Currently, other than all the engine/trans wires being disconnected, the only things changed are the injector fuses are out as I'm tapping into switched power there for my new harness and the ecm is unplugged.
Anyone got any ideas?
Ghettobird52
Jul 5, 2024 11:18 PM
