1989 5.7 iroc starting problems
Old Jun 27, 2010 | 08:10 PM
Racer#6's Avatar
I have a 1989 iroc camaro 350 tpi. it doesn't turn over by key unless i bypass the stater enable relay. then it will turn over. but there's no spark and the car still won't start. any help is much appriciated
Old Jun 28, 2010 | 04:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1989 5.7 iroc starting problems
Sounds like a VATS issue maybe - you are disabling the VATS on the starter side by bypassing the starter enable relay, but not bypassing the VATS on the other side where VATS disables the fuel injectors. Do you have another key to try?
92camaroJoe
Jul 29, 2023 07:57 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Rustyweb7
Aug 9, 2015 03:05 AM
