Help, lost part
Old Jun 30, 2010 | 08:34 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Help, lost part
It's been a while since things were coming apart off the car, now that things are coming together, little things are fading as to where they came from...
Any help would be appreciated. The below piece is missing a home. I thought it came from the main harness coming from the fuse block at the fire wall, but I don't see how it would go on.
Old Jun 30, 2010 | 11:32 AM
Drew's Avatar
Re: Help, lost part
That's the clip from the engine harness... The harness passes through the passengers side kick panel, and that piece slides into it to lock it in place.
Old Jun 30, 2010 | 11:53 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Re: Help, lost part
Drew, thank you very much. That is where I thought it came from, but I can not figure out how/where it clips on the engine harness. Does the clip go on the engine compartment side, or the cabin side of the firewall? Is there a way I could bother you of a photo of it installed?? Was the clip suppose to go between the harness and the firewall prior to screwing it back in?
I tried it on the engine compartment side of the harness, but the clip seems too small if trying to clip it over the top, and too big if clipping it over the side, not to mention the studs on the sides of the harness...
Old Jun 30, 2010 | 12:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Help, lost part
It goes on the other side of the car - the pass side, where the ECM wiring harness goes into the fenderwell and through to the pass side footwell.
Old Jun 30, 2010 | 01:53 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Re: Help, lost part
Oops , yeah passenger side... Cool, should fit much better on the right side of the car!
Thanks both! It will probably make more sense when it's in front of me, but it'll be on the inside or outside of the car?
Old Jun 30, 2010 | 06:29 PM
Drew's Avatar
Re: Help, lost part
Inside. The C100 connector under the master cylinder doesn't need the keeper since the screw keeps it in place. The engine harness however just goes through the bulkhead and that C clip slips into a groove to keep it from pulling out.
Old Jul 1, 2010 | 08:18 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Re: Help, lost part
Thanks again Drew! I took a look last night and looked much more like a match.
LT1Formula
20
Nov 14, 2015 12:02 AM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
