how can i start my firebird with out a key
Old Jun 29, 2010 | 02:51 PM
solin777's Avatar
Car: 91 Formula Firebird
Engine: 305 tpi
I recently purchased a 91 firebird from a tow yard, it was a stolen recovery so there is no key and the steering coloum is torn up. I just want to know if the motor runs good or not. Thank You
Old Jun 29, 2010 | 02:57 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: how can i start my firebird with out a key
dont think you can...
Old Jun 29, 2010 | 03:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
bypass vats, switch the ignition to on by pushing the rod that is normally attached to the lock cylinder and push it down.
Old Jun 29, 2010 | 03:56 PM
solin777's Avatar
Engine: 305 tpi
how do you bypass the vats key I was going to with a reostat to reach the correct resistance but is there a easier way
Old Jun 29, 2010 | 04:10 PM
Zepher's Avatar
rheostat is the easiest/cheapest way but there are 15-16 values and there will be a 5-10 minute delay per try, maybe longer.
other way is a memcal with VATS turned off. the memcal is the module that is plugged into the ECM.
here is a list of resistance values,
http://www.p71interceptor.com/thirdg.../vatsinfo.html
Old Jun 29, 2010 | 04:31 PM
solin777's Avatar
Engine: 305 tpi
What is a memcal? Do I just get a reostat from radio shack and how do i wire that in
Old Jun 29, 2010 | 04:50 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
You can go to a shop that does remote starter and such. They will have a pack of restistors called a VATS PACK. It will have all 15 different restistors you would to bypass the vats key. If you don't know of a shop around, you can order it online just seach for VATS PACK
Old Jun 30, 2010 | 12:25 AM
solin777's Avatar
Engine: 305 tpi
where do i locate the vats module and does anyone have a picture of the module
Old Jun 30, 2010 | 07:13 AM
Drew's Avatar
It's on the back of the passengers side dash.
Old Jun 30, 2010 | 09:54 AM
solin777's Avatar
Engine: 305 tpi
I found a few boxes behind the dash but nothing that matches the wiring colors
Old Jun 30, 2010 | 11:25 AM
Drew's Avatar
It's a black plastic box bolted to the back of the dash hull, up behind the dash. The only time I've ever seen one was after I pulled the entire dash. You probably can't see it or get at it with the dash still in the car.
Theoretically, you can bypass VATS by grounding the starter enable relay, and the VATS enable wire from the ECM, since that's all the VATS box does when the correct resistence key is used. However that's just a theory.
Old Jun 30, 2010 | 11:42 AM
Stephen's Avatar
Car: 87 GTA
You don't have to reach the box. You just need to reach the 2 wires from it, that go into the steering column.
See post #6..... https://www.thirdgen.org/forums/elec...stor-help.html
But without the key, there is no way to determine what resistor value it is looking for. Normally you test the key to determine which of the 15 resistors you need. Without the key, you'll hafta get all 15 & test 1 by 1.
Old Jun 30, 2010 | 12:01 PM
solin777's Avatar
Engine: 305 tpi
I was planning on bypassing the vats box i just wanted to make sure it was still in it cause the guy at the tow yard said it was gone so i just wanted to make sure it was still there
Old Jul 1, 2010 | 09:31 AM
solin777's Avatar
Engine: 305 tpi
Last night i tried my luck at bypassing the vats. I didn't get very far.... When I turn the key on is anything supposed to come on because nothing would turn on. Is there a main fuse anywhere before the fuse pannel? Tonight Im going to get in there with a test light to see if Im getting power to any thing or not.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Randomtask2
Aug 13, 2015 01:57 AM
