dead short
Old Jul 5, 2010 | 07:32 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
dead short
Need help finding my short.I have done a complete 94 z28 wiring from the front to the back, lights, engine everything. no problem until this year.
I unhooked the ground wire put the volt meter between the bat and ground wire and it's pulling 12 volt with nothing turned on. I have spent the last 4 hours pulling every fuse and relay and still pulling power. I unhooked the starter and altenator and still pulling power. I unhooked the computer and split the car in half at the firewall and still have a short. Any idea what to look for next, I can't think of what to unhook next.
Old Jul 6, 2010 | 12:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Short End Of The Short
A voltmeter in series with the battery is not a reliable way to find a short, especially if it’s a high Ω/V meter.
It can show 12 volts even if it’s going thru a properly loaded circuit.
Throw a small bulb such as a side-marker bulb in series instead.
Now you’re ready to hunt for shorts.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Jul 6, 2010 | 01:10 PM
Engine: 400 and 350
Re: dead short
Thanks for the hint. I will see what happens.
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
