i need some wiring help
Old Jul 6, 2010 | 12:41 PM
affliction1's Avatar
Car: 89 chevy camaro rs
does the 1989-1992 firebird have the same steering column wiring harness as the 1989-1992 camaro column?
Old Jul 6, 2010 | 04:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: i need some wiring help
There may be a few differences - some of the 'birds had radio controls on the steering wheels where Camaros never had, but majority of it should be the same.
Old Jul 6, 2010 | 05:19 PM
i do have an 88 camaro column but im not sure if it would wire up to my 90 due th no vats or airbag,do you know anything about it?
Old Jul 6, 2010 | 06:01 PM
Car: 1992 RS
Engine: Carbed 350
Airbag wouldn't be an issue, you just wouldn't have a functional air bag anymore.
Vats would be an issue, but you can disable the vats on the car side since the 88 column wouldn't have the vats wires/switch: www.thirdgen.org/vats
Old Jul 6, 2010 | 07:32 PM
but would the wiring harnesses be the same like for blinkers wipers exc.
Old Jul 8, 2010 | 07:06 PM
Pocket's Avatar
Car: 91 Trans Am
The outer plastic housing is slightly longer for the airbag steering wheel. Wiring can be swapped over for any changes
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
