92 put eddlebrock intake on and distributor will not fit
Old Jul 12, 2010 | 05:22 PM
j23nyj's Avatar
i bought a new eddlebrock intake and when i try to put the distr in it will not go all th e way in it sits like 1/8 inch to high it will not seat in. i put the distr in thru the old intake and it fits flush i have no clue what to do please help
Old Jul 12, 2010 | 05:58 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Re: 92 put eddlebrock intake on and distributor will not fit
have u tried popping off the cap and twisting the rotor see if it falls in?
Old Jul 12, 2010 | 05:59 PM
Awesome-X's Avatar
Car: 87 Camaro
Theres a shaft in the distributor that has to line up with the oil pump thats inside the motor block. Look at the very bottom of your distributor and you'll see it. You have to move the oil pump shaft in the block to line up with the shaft in the distributor or it wont sit all the way down. You can use a really long flat head screwdriver.
Old Jul 12, 2010 | 06:21 PM
j23nyj's Avatar
it seems like its all lined up but the way the neck on the dist is like two tiered the smaller (bevelled) part seems to not fit thru the distr hole in the new intake it seems like it gets stuck and doesnt even have a chance to sit on the gasket
Old Jul 12, 2010 | 06:26 PM
Engine: 350 tpi
so its not sitting? or its not going thru the hole in the intake? what intake did i get part number?>
Old Jul 12, 2010 | 06:37 PM
j23nyj's Avatar
It's an edelbrock performer tbi manifold model # 3704..it goes thru the hole in the intake 99% but there's about a nickels width of space between the distributor and the intake that wont let it go flush
Old Jul 12, 2010 | 06:45 PM
Engine: 350 tpi
im more than positive its the bottom shaft of the distributor not lining up with the pump...thats the problem i was having when putting my distributor in it looks a little off...pop off the cap and move the rotor it will fall right in when its lined up perfect.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Jake_92RS
Aug 11, 2015 10:39 AM
