fuel guage help!!!! important nd to know now!
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
hey i have my cluster apart and how do i check my fuel gauge? the battery guage moves with little effort (goes back down when i move my finger tho lol) oil and temp gauges move with little effort and stay put. but my fuel guage takes more effort then the others and stays. is my guage bad?? as it doesnt work as it is, its always pegged above full.
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: fuel guage help!!!! important nd to know now!
Hey, there. It's Tim from the lake. IIRC, pegging at full means that you have no ground signal.
This can be due to a broken signal wire... in the case of my GTA, it was a lot of cruddy residue on the wiper assembly in the tank. In other words, my sending unit was all gunked up.
I know that in the older cars (I'm talking 60s and 70s here) the gauges usually operated on about 3V. We used to take a flashlight battery ("D" cell) and connect it across the gauge terminals. It would make the needle go up or down, depending on the polarity of the connection (ie, where you connect + and -). Since the "D" cell was 1.5V, it would make a properly functioning gauge read about half with the correct polarity.
I don't know what voltage the thirdgen gauges operate on, but you could try the "D" cell and see what happens. If nothing, then try two in series. If the gauges work on 12V, that should give you at least some movement, and I am guessing with correct polarity it would give you a reading of around 3/4 full.
Engine: 305 tbi
hey. but what about the firmness of the needle? and also if i had a bad ground wouldnt other things be affected to?
Car: 88 GTA
Transmission: WC T5
That gauge has a stiffer needle because of how it operates.
The sending unit in the tank applies a ground signal through a variable resistor to tell the gauge where to move the needle. If that signal is totally absent, you get a 'full tank' reading. Since the gauge is grounded through the sender in the tank, it does not affect anything else. All other indicators are grounded to the chassis.
Engine: 305 tbi
aaaa and i suppose to find the no ground singal would be to drop my tank...?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sending Information
Nope.
To find out if the sender is grounded and working disconnect the sender wire going to the gage and measure between the sender wire and ground with an ohmmeter.
It will read between 0Ω and 90Ω if it’s OK.
Happy Racing!
Spin Me This Week … I’ll Spin You Next Week
Happy Racing!
Engine: 305 tbi
Re: Sending Information
Nope.
Happy Racing!
Happy Racing!
Transmission: 765R4
Sending Information
No need to turn the car on.
You can find the wire going into one of the dash connectors.
It’s a purple wire.
Happy Racing!
It’s a purple wire.
Happy Racing!
Engine: 305 tbi
well finally got my hands on a ohm reader and interesting thing the wires coming from the sender they tested at 88.7 ohms after a few seconds of bouncing between 80-120. ok wtf? the tank isnt full (i dont think)(but it might, trying to figure out the dieing problem) but anywas so then im like hmm the gauge? so i tested the same wire connectors on the gauge cluster and after extreme jumping it settled on 166.3 ohms...ok wtf? a 0-90 ohms gauge at 166...so im thinking (with others) that the guage is bad. i just want to make sure before i go and buy a new gauge. Thread Starter
Engine: 305 tbi
ok so today i topped off my tank, took in 7 gallons (12 gallon tank) which menas yesterday it had 5 gallons so it should of read 45ish ohm oppsed to 88 right?
Transmission: 765R4
Sending Information
You are correct.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Happy Racing!
Engine: 305 tbi
Ghettobird52
Jul 5, 2024 11:18 PM
Ozz1967
Aug 16, 2015 10:23 PM
