Blinker always on?? (help)
Car: 89 IROC Z28 Vert
So i recently changed my blinker bulbs and now the drivers side blinker is on constantly. not blinking but just on bright. i think its a grounding issue but didnt see any loose wires. Any suggestions?
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Blinker always on?? (help)
and you tryed a diff bulb, (another new one)
also check the flasher relay
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
had the same problem, changed the relay and it blinked again but stayed lit on my dash when I turned my lights on. I changed the bulb under the hood and got rid of the problem.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i had the same problem.ended up being a worn ground within the light socket....replaced the socket and installed a new bulb...works wonderful now
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Transmission: 700 R4
Axle/Gears: 3-73
you have the wrong bulb in some where in the circut or has gone loose the glass not the socket
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
