I cant find my 02 plug ive been looking for hours
Old Jul 13, 2010 | 01:58 AM
86Stevo's Avatar
i looked online to see if i can find out were its suppose to come from but i cant find any picture or anything
i was wondering if some one would be able to take a picture of the 02 wire for me ?
this would also help every one els who cant find there 02 plug also since i noticed alot of mysterious 02 plug/wire threads around
what harness it comes out of would be great also i looked under the wiper motor and didnt find anything at all followed the harness all the way back to the dist. and didnt find any empty plugs hanging out there i doubt it would be on the passenger side of the engine
Old Jul 14, 2010 | 03:01 AM
86Stevo's Avatar
Re: I cant find my 02 plug ive been looking for hours
bump......any one?? any help at all?
Old Jul 14, 2010 | 08:04 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the O2 sensor plug should be a single wire connector on the driver side, probably hanging around near the motor mount area. it will be part of the main harness.
Old Jul 14, 2010 | 01:31 PM
SPL_II's Avatar
If you get up under your car and look where the exhaust pipes run to the manifold (on the drivers side) you will see where it connects into the manifold, just follow the wire from there.
Old Jul 14, 2010 | 09:41 PM
t-ray10's Avatar
Car: 1992 Camaro RS, 2012 ZL1 on order
Engine: 5.0 305, 6.2 Liter LSA SC
Transmission: T5, TR6060
Axle/Gears: stock, 3.73
ya, it should be on the drivers side screwed into the exhaust manifold. The wire raps around the front of the car and connects to the other relay wire at about cylinder, or the front drivers side of the block
Old Jul 14, 2010 | 11:20 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Since the OP didn't mention which motor he has..
On the V8 cars, it's on the driver side manifold, and the plug is part of the main harness as 1ADan has noted.
For the V6 cars, its just in front of the cat in the Y-pipe.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
apie2546
Aug 8, 2015 07:12 AM
