need help please headlights went out - 1992 v6 camaro
what fuse controls the headlights i cant seem to find the label on the box.... i cant drive the car and i need it for work... both the high and low beams are out and wont work at all... what should i do
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: need help please headlights went out - 1992 v6 camaro
Check the dimmer switch under the dash, mounted on top of the steering column. It has the metal rod from the blinker stem connected to one end to activate its switch. You will also find the ignition switch there with a similar rod coming from the ignition lock cylinder.
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
hey bud what did you figure out...i have the same problem with mine....dimmer switch wont click anymore and no headlights at all..... no power going to the connectors....lmk. thanks
Car: 1988 Camaro Rs
Engine: LH0 V6
same.. my high lights are out.. but city lights work but would like to know how to get them back on aswell
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Juct check all the fuses on the fuse box on the drivers side above the pedals.
did check all fuses.
all ok
all lights are working except for no headlights at all
new bulbs...still inop
no power going to connector
dimmer switch is not clicking anymore...rod is hooked up...doesn't click even with pushing by hand.
would dimmer switch cause no headlights at all...or just no high/or low (one or the other)
all ok
